Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
This pin is missing in my Z87 LGA1150 motherboard, need technical information about it.
Community Manager
This pin (below picture) is missing in my Z87 (asus maximus vi formula) motherboard. I did some research and find out it was a VSS pin (although still need a technical confirmation). From what i heard "motherboards can function without a VSS pin but only if it is bridged to other ground pins." I'm not 100% sure if this is a VSS pin or if it's bridged to other grounds?
I need to be make sure this motherboard can still function with a proper cpu. So i need techinal informations on this matter. Here is the picture:
Higher resolution picture: http://i.epvpimg.com/MKrre.jpg http://i.epvpimg.com/MKrre.jpg
That would be great to be make sure this motherboard can still work without this pin. Thanks for any technical help!
AlHill
I believe only ASUS can tell you if THEIR board will work without that pin.
I would contact ASUS support for clarification.
Doc
Community Manager
Thank you for your answer. I will to try to contact with them.
Community Manager
Hello:
Thank you very much to Al Hill for the information posted previously.
To brky94:
I just wanted to confirm the information posted above, in this case, since the board was manufactured by ASUS, the best thing to do in order to get the information you are looking for will be to get in contact directly with them.
ASUS's support site: https://www.asus.com/us/support/ https://www.asus.com/us/support/
ASUS's phone number: 1-877-339-2787
Alberto
