Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
Troubleshooting DP55KG That Shows No Sign Of Power
CLO5
I had built this dp55kg-pc six year ago. Now, my pc failed to boot with no sign of power. Please help me to troubleshoot it to either a faulty cpu or a faulty motherboard.
1. The psu is good.
a. Disconnect all connections from psu.
b. Short Pin16(PS_ON# )/Pin17(Ground) of the 24Pin Power Connector with a paper clip.
c. Switch on psu.
d. psu fan starts to spin. +5V/+12V can be measured with a DMM.
2. A faulty cpu or a faulty dp55kg?
a. Take out CMOS Battery and measure 3V with a DMM. Look good. Then put it back.
b. Disconnect everything from the dp55kg, except for the 24Pin Power Connector/2x4Pin Power Connector/4Pin CPU Fan/Rear Case Fan.
c. Switch on psu.
d. Momentarily short the red Pin6/Pin8(power switch) of the front panel header on the motherboard with a screwdriver.
e. No beep. No fan. No Post Code LED. No Processor LED. No Voltage Regulator LED. No +5V/+12V.
f. Standby Power LED turns green. Back2BIOS Button is red.
Thanks Forum! Hope You Can Help!
cibalo
AlHill
How do you know that the PSU is good? Try a different power supply before we go any further.
Doc
AlHill
Doc
CLO5
Your question is answered in the part 1 of my post.
1d. psu fan starts to spin. +5V/+12V can be measured with a DMM.
AlHill
What you have done to test the power supply does not mean it is working. Try a different power supply first,
Doc
Community Manager
Thank you, Al Hill for your help.
Ciba_LO, please let us know if you need further assistance.
JC
CLO5
In fact, I did replace the psu with a brand-new working one, verified at the service center before I posted the message. And all symptoms remained the same after the replacement.
Community Manager
Hello Ciba_LO,
Thank you for the information.
At this point, the only way to be 100% sure whether is the processor the one defective or the motherboard is to get a spare CPU or motherboard to test with.
JC
Community Manager
Hello Ciba_LO,
I was reviewing this thread and I wanted to know if you need further assistance?
If so, please don't hesitate in replying to this post.
JC
