Intel® Desktop Boards
Peer-to-peer support only
11435 Discussions
Two Hyper-V Problem on Dell All in One XPS 2720
sredd19
Agenda: I am planning to run two Hyper-v at same time in my "All In One" desktop( dell xps 2720 i7 4770s, 16gb ram, windows 8 pro 64bit)
Recently I had a problem with my desktop and I have to reset my desktop, post reset I am trying to run two hyper-v at same time. Initially I have added the "hyper-v" feature and also I enabled hyper-threading and visualization in the bios. Although both the mandate steps are enabled but still I can't run two hyper-v at same time. As a test, when I run Hyper-v individually then it runs, however when I try to run together then it fails.
Previously before the reset I was able to run two hyper-v's. It seems to me that something has changed accidentally. Any suggestion would be appreciated.
BIOS Setting.
Intel Hyper-Threading Technology - Enabled
Intel(R) SpeedStep Technoglogy - Enabled
Intel(R) Virtualization Technology - Enabled
CPU XD Support - Disabled
Limit CPUID Value - Enabled
Multi Core Support - Enabled
Intel(R) Turbo Boost Technology - Enabled
Regards, Sidd
Silvia_L_Intel1
Sidd,, we know for sure the I7-4770s processor supports Intel(R) Virtualization Technology, and it is enable by default in BIOS in our motherboards. Since you have an OEM system, I would recommend you to contact DELL.
