Community
cancel
Showing results for
Search instead for
Did you mean:
PRoja1
USB 3.0 Front Panel Ports for DH77EB do NOT work. Solution?
I have a DH77EB Motherboard in a PC running Windows 7 64 bit and have all the latest drivers as well as the most recent bios available to date.
One front panel port works for some devices. the other does not work at all.
The case is brand new and the cabling is fine. I have the header plugged into the correct port on the motherboard as well.
What is the problem?
Silvia_L_Intel1
Armorlight, there are many BIOS version that fixed issues related to USB 3.0.
According to your post, you already have the latest BIOS version installed. Do you know which BIOS were flash on your system before the latest one?
You may want to test your system out of the chassis, minimal configuration such as motherboard, processor, power supply, 1 memory stick.
You can also try removing the CMOS battery and leave the system without it for about an hour. Then put it back on and restart the system. http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime
Which devices are being recognized on the working USB port?
