Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
USB 3 not working properly on DH67BL
PGang
On the DH67BL I just cannot get a USB 3.0 drive [Expansion 1TB] to work. It works fine on USB 2.0 ports and also USB 2.0 devices works fine on the USB 3.0 ports.
I have updated the BIOS and Renesas driver and do not have any bios optimization enabled. It detects the drive sometimes but quickly disconnects and eventually stops detecting.
I see two issue using UVCView.x86, the same physical port is detected as port 2 for USB 3 device and port 3 for USB 2 device on the USB 3 RootHub
And bMaxPacketSize0 as 0x09 when the USB 3 drive is connected to the USB 3 port
And *!*ERROR: High Speed Devices require bMaxPacketSize0 = 64, also the MaxPower is detected as only 36mA
It works perfectly on the USB 2.0 ports. bMaxPacketSize0 is detected as 0x40 and MaxPower as 500mA
Tried to search for any clues on intel community and elsewhere and tried out many small changes [power managment, disable USB optimization etc] but just couldn't get it to work.
Appreciate if anybody has some suggestion as to what could be wrong here. Have attached UVCView output for USB 3 and USB 2 ports just in case somebody can make sense out of it.
Renesas: Driver 2.1.28.0
Firmware 3028
Board: DH67BL
Version: AAG10189-211
BIOS: BLH6710H.86A.0160.2012.1204.1156
Pritam
Pritam
Kevin_M_Intel
Hi Pritam,
I am sorry to hear you are having problems but let me help you.
The assistance will be provided on the following link:
/thread/27750 https://communities.intel.com/thread/27750
