Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
USB boot device bug still present on DQ77MK
MNawr
Greetings Intel Community:
Before I discuss the issue at hand, I do want to say that my current Intel motherboard is by far the best I have ever used in all my adventures in building PCs. It supports GNU/Linux exceptionally well and the AMT and vPro capabilities are second to none. That being said, I do have this annoying issue which requires me to employ inconvenient workarounds to mitigate the issue. What happens is that I cannot boot from any USB-connected flash drive or external hard drive without causing the motherboard to enter an infinite reboot cycle when the Intel Desktop Board logo appears at power on. Normally this wouldn't be a problem, except that I need to boot off USB for installing operating systems and whatnot.
I did discover a discussion from early last year that mentioned this software defect for booting off USB on the DQ77MK and that Intel was aware of the problem and working towards a solution (/message/189032# 189032 https://communities.intel.com/message/189032). Sadly, as of the latest revision of the BIOS (0064) from October 2013, which I happen to have installed at the moment, I still encounter the endless shutdown and restart loops every time I plug in a USB drive to boot off of. Since this motherboard is covered under Intel's eXtended Life Program, is there going to be an actual fix coming soon? For an otherwise stellar motherboard to have this bug is rather inexcusable, since working with USB drives at the BIOS/EFI level should be a bug-free experience.
Thank you for your attention to this matter.
Silvia_L_Intel1
Hello Nawrocki, I'm glad to know that you are satisfied with our products.
I would like to inform you that there is a new BIOS version 065 in our download center. https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23728&lang=eng&OSVersion=%0A%09%09%0...
However, I would like to know if you installed BIOS 0054, 0060 and 0061 previously. These BIOS versions appear to have some fixes related to USB ports.
Let me have your results.
Silvia_L_Intel1
MNawr
Hi Sylvia!
Looks like the latest BIOS eliminated the issues quite nicely for me. Thank you for your help!
As an aside, I did flash those other versions of the BIOS that you mentioned in your reply post.
Silvia_L_Intel1
Thanks for your feedback. I'm glad it worked!
