Intel® Desktop Boards
Peer-to-peer support only
11477 Discussions
Unable to Install Windows 7 in DG41TY Motherboard
Community Manager
Hi All,
Recently I've brought a DG41TY Motherboard and trying to install windows 7 ultimate,but failed several times on installing the win 7 OS.
the OS installation process continuing till giving the credentials to finish the installation after that i should've get the desktop screen but I'm getting the welcome screen after the machine automatically started to restart after the restart a blinking black screen and nothing more than that. i even tried of upgrading the BIOS too but still no luck.
when i tried to install windows XP professional SP3 it worked and I'm able to work with it.
Note : I'm using INTEL core 2 Duo Processor 2.2 GHz
please consider this as a help provide me a solution to it.
Community Manager
Hello Saranraj,
If you are able to successfully install a different Operating System, our recommendation is testing with a different installation cd or media to narrow the issue properly. Make sure you are following a clean installation of the Operating System using all latest drivers from our website:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/dg41ty Support for the Intel® Desktop Board DG41TY
Community Manager
Hello Saranraj,
Community Manager
Hi All,
I have core 2 duo 2.2 ghz and recently changed my motherboard from asus to intel DG41TY.
I tried installing several times and used different media too, however every time the OS installation process continuing till the credentials to finish the installation after that i should have get the desktop screen but I'm getting the welcome screen after the machine automatically started to restart after the restart a blinking black screen and nothing more than that.
I even tried different version of win 7 but it failed. Please note that the same win 7 version were easily working on my ex motherboard and still work perfectly fine in my second desktop using the same cd drive.
Your quick help will be appreciated.
