Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
Unable to boot DP45SG
skuma77
Hi All,
I am trying to create a NAS Server and using free motherboard (DP45SG) i have for this purpose.
I have a Core2Duo Processor and installed a Single DDR3 (4GB) RAM into DIM0 Slot.
The memory module i am using is Crucial Ballistix DDR3 PC-10600 4GB CL9 1.5V
And the power supply (BFG) is rated at 600W.
When i powered on i don't see any thing on my monitor. All i hear is three beeps (as per the documentation it has some thing to do with the memory (i might be wrong).
I checked the following multiple times and still no luck booting the system.
1) SPI_CON Jumper is in the correct spot. i.e, on pins 1 and 2.
2) CMOS Jumper is also placed properly (on the bottom two pins). i.e, pins towards the battery.
As shown in the pic included/
3) BIOS Jumper is also placed correctly. i.e, on pins above the label BIOS.
any suggestions please.
ZAgha
New Contributor II
Three long beeps means memory error http://www.intel.com/support/motherboards/desktop/sb/CS-025434.htm Desktop Boards — Port 80h POST codes
The RAM you are using is considered a high dense memory chip for the DP45xx. The Max supported ram on your MB is 8GB. Hence, you should try a smaller compatible RAM
Make sure you have the latest BIOS
Tell me how it goes
skuma77
Hi Ziad,
Thanks for the info.
Yes i am planning to get 2 X 2G DDR3 Memory Sticks and try my luck.
Also how can i update the BIOS if i cannot see the post screen. All the documentation that i have gone through to update the BIOS are once you successfully boot the system. Am i missing some thing ?
DArce
Valued Contributor III
mars76, try as Ziad Aghar suggested, as its a very good recommendation and troubleshooting step.
Concerning the BIOS update, you can try a bios recovery as instructed here:
http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htm http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htm
Be sure to disconnect all peripherals not required for the update, even the mouse, keyboard, hard drives and any other CD/DVD ROM, this may take up to 15 minutes even if there is no display on the system
The file you need to use is posted here:
https://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/18636/eng/SG0... BIO File - version 0125
skuma77
I tried both the RAMs listed above and still getting three beeps.
Not sure what else i can try..
i installed only one memory stick (2GB) in DIMM 0 Slot for each of the above types.
also tried with both the sticks on blue DIMM Channel and still got three beeps !!
Any suggestions pls.
DArce
Keep in mind that the highest that this motherboard is able to support is 1333 mhz. Check the memory specifications at:
http://www.intel.com/support/motherboards/desktop/dp45sg/sb/CS-029151.htm http://www.intel.com/support/motherboards/desktop/dp45sg/sb/CS-029151.htm
I would suggest you to take the system out of the chassis, place it on a non-conductive surface like a newspaper, a magazine or something similar, leave only motherboard, power supply, processor and Heat Sink/fan. Remove all the rest of components
Clear the CMOS removing the CMOS battery and all power cables from the power supply to the motherboard, leaving the system without power for 20 minutes at least. After the 20 minutes reconnect the 2x12 and 2x2 power cables. Power up the system and check if the system beeps
Then add one memory stick and try a BIOS recovery with the instructions on the following site: (you don't need video to try this)
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm
BIO file for BIOS Recovery Update [SGP4510H.86A]
If still, the problem continues, a replacement should be done. So check with your local support on this. For contact information you can refer to:
http://www.intel.com/support/9089.htm http://www.intel.com/support/9089.htm
skuma77
Hi ,
I tried as you mentioned and once i add memory i am always getting three beeps.
Not sure whether the BIOS Update happened or not as it still gave 3 beeps.
I am getting a POST BIOS PCI Card to see what's the actual code it is sending.
In the mean time i will try to get different memory and give one more shot.
DArce
Okay, try changing the memory sticks and using other memory slots and check if the result changes
ZAgha
New Contributor II
Correct me if I am wrong:
You have tried more then 3 different RAM sticks. Two of them are supposed compatible, "If I were you I would eliminate the RAM problem". You took the MB out of the case & tested it with minimum settings "Exactly like Diego instructed". That didn't work also
You tried to update the BIOS via recovery method. Yet that didn't work.
This is an old board. So was it working before? or was it stored properly?
With all do respect, cut your losses & stop spending money. Try Diego's last tip. If that didn't work then you have a faulty MB.
skuma77
Hi All,
I got my POST Tester Card and installed into the PCI Slot and with out any memory i powered it on and the POST Tester displays the Code "2F 23".
The Manual has the following for the above beep codes..
2F
Award Initialize Slot 15
AMI The EGA/VGA controller was not found.The display memory read/write test is about to begin Enable Cache
Phoenix4.0 Enable Cache before system BIOS Shadow.
/Tandy3000
23
Award Initialize Slot 3
AMI Reading the 8042 input port and disabling the MEGAKEY Grren PC feature next
Making the BIOS code segment writable and performing any necessary configuration before initializing the interrupt vectors
Phoenix4.0
/Tandy3000
I cannot make out what these codes mean !!
Really appreciate any help..
skuma77
After installing the new memory now i can get into the boot screen how ever the System shuts down immediately.
I saw CMOS Checksum Warning at the beginning.
Form the second image the version of the BIOS that's installed is
SGP4510H.86A.0125.2010.0121.1927
Also one last thing i forgot to mention: i am not using the front control panel wires to start and stop the computer. i am using PSU on/off switch.In fact the only things that are connected to the motherboard are:
1. 24-pin (2 X 12) ATX Connector
2. 4-pin (2 X 2) connector
3. 4-pin molex connector
4. Keyboard & Mouse
5. VGA Display Card
DArce
At this point you might try the system out of the chassis placed in a non conductive surface, test another CMOS battery, try a BIOS recovery update and test another power supply. That would be all possible troubleshooting left.
