Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
Unable to connect Apple Thunderbolt Display on new Thunderbolt Drivers on HP Spectre X360
SSuff1
Hello everybody,
I have a issue with the new HP spectre x360 and new Thunderbolt Drivers, I'm not able to change the security level of the Thunderbolt device and as I have seen, by default only Windows-certified devices are able to be connected to the computer.
I have an Apple Cinema DIsplay with a Thunderbolt 3 to Thunderbolt 2 adapter. This one work very well with my company computer ,an Elitebook HSN-104C.
When comming the time to change my MacBook pro and as the Elitebook works very with my Apple Display I have chosen to get a new HP for my daily driver.
I have seen on the forum that this issue could be solved with a Thunderbolt firmware utility to change de default behavior to accept all Thunderbolt device but I'm not able to find it for my new computer.
The Spectre has a Thunderbolt Controller 8A17 with the Intel Controller 1.0.24.0
The Elitbook has a Thunderbolt Controller 15D9 with the Intel software ver 17.4.78.500
Already tested :
I have tried to update the bios -> Nop.
I have tried to use the Intel Software ver 17.4.78.500 -> Dosent's seen thunderbolt controller
Check into the Bios Settings to change Thunderbolt security level -> Not present.
For reference a post that solve the issue on others Spectre devices and Thunderbolt Display :
https://h30434.www3.hp.com/t5/Notebooks-Archive-Read-Only/Apple-Thunderbolt-display-with-Spectre-XT-...
For reference post with default behavior of Thunderbolt Firmware on HP Devices:
https://support.hp.com/us-en/document/c03725328
many thanks in advance for your help !
Have a nice day
