Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
Unable to install windows 10 after dozen tries.
ManuelMerricksin
Good morning. I have Intel core 2 DUO E8500, 3.16 Ghz desktop computer. I have tried several times to install windows 10 on it but always getting a blue screen. I strongly believe it is a configuration in the BIOS which is preventing the installation or something. Can someone tell me how to install windows 10 on it. Any help will be very much appreciated. Thank you.
LeonWaksman
1. I suggest you to reinstall Windows using the following method:
2. Please prepare your installation media (you need 8GB – 32GB USB stick), using Microsoft Media Creation Tool. This will install version 2004. Use this instead of installation media you have.
3. Your bios should be set to default settings. Usually you enter bios by pressing F2 during boot and then press F9 (Y) to set defaults and F10 (Y) to save settings and exit. Could be that you need other keys to use in your computer.
4. With the installation media inserted into USB slot, power ON your computer.
5. Follow this tutorial to continue with installation.
6. In para. 8 you may enter Product Key from the Microsoft Distribution you bought or click on the I don't have a product key and Windows will be activated later.
8. Skip on para. 13 and continue in para. 14. Important, do not format drive where you want to install Windows, rather delete all existing partitions from this drive, till you see one unallocated space.
9. Press Next and continue with the installation.
Leon
AlHill
Whose desktop board?  Provide the manufacturer name and model.
Doc
ManuelMerricksin
Its an Intel desktop board. I see 210882, D33025. I don't know which is the model but it is an Intel desktop board.
AlHill
Those numbers do not look correct.  Look on the board for an "AA" number.
AlHill
Also, from where did you get your windows 10 install media?
ManuelMerricksin
Yes yes, it is AA D82085-804. Attached is a picture of that.
I downloaded it from a site called igetintopc.com and the bootable was created using Rufus
ManuelMerricksin
Picture of the motherboard model
AlHill
Sounds like you have a DQ35JO
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/desktop-boards/P35_G35_Q35/D...
https://ark.intel.com/content/www/us/en/ark/products/50382/intel-desktop-board-dq35jo.html
From where did you get your windows 10 install media?
From looking at your photo, I am concerned about the condition of the board.
ManuelMerricksin
I downloaded the windows from igetintopc.com and I used Rufus to make a bootable.
The board is functioning alright. It had XP3 installed at first and it run smoothly; it is when I try to install windows 10 that I always get the blue screen error.
AlHill
We see this all the time.  Do not go to any place but microsoft to make the install media.
Go here and follow the instructions to create the install media.  Do not use rufus or any other tool.  Just have a usb2 stick of at least 8gb.
https://www.microsoft.com/en-us/software-download/windows10
when you install w10, when you get to the point of selecting the drive, delete ALL partitions on the drive you want to install W10 on.
ManuelMerricksin
Okay I will try and give feedback
n_scott_pearson
Super User Retired Employee
While you are at it, get yourself a bottle of compressed air and clean the crap out of the system, off the motherboard, around the processor and especially in and around all fans. Remember to spray air into the power supply (via Internal port so dust is vented out exterior fan opening).
Based on how much dust is adhered to the motherboard, there is so much dust in your system that you better take it outside to do this cleaning.
AlHill
The dust was covering the board model number<G>
ManuelMerricksin
Very appreciative. Will do that. Can I use air from standing fan??
AlHill
Doubtful that would be strong enough.
ManuelMerricksin
ManuelMerricksin
@leon Waksman, AlHill, n_scott_pearson and any one helping; it is still behaving as such. Still giving me the blue screen. I have created a bootable media using Microsoft media creation tool but when tries to install, it still gives me the blue screen error. What must I do please??
AlHill
What error are you getting?  Take a photo of the blue screen.
Also, provide your memory information and your HDD information.
ManuelMerricksin
Attached pictures of memory, hard disk and error messages.
The memory are four and they are all installed. Hard disk is showing. The error messages are two:
1. When you call a support person, give him the info: PAGE FOUND IN NONPAGED AREA
2. IRQL NOT LESS OR EQUAL
AlHill
I am suspecting a memory error.
How many sticks do you have and what density?
Also, removed ALL unnecessary devices - dvd, printers, scanners, etc.  Keep only the boot drive, mouse, keyboard, monitor.  Unplug everything else.  Try again.
