Community
cancel
Showing results for
Search instead for
Did you mean:
OLuk
Unable to uninstall Intel support assistant: "the installer does not support interactive installation"
Assistant Version:19.6.26.3
Windows 7:
AlHill
Are you running SP1 plus the 400 additional updates?
Doc
OLuk
Of course.
SBasr
I have the same problem on Windows 10 1903.
I solved it by uninstalling every Intel Driver and Support I can do. Then I downloaded the intel driver & support assistant 19.6.26.3 and installed it. I then unplug my ethernet and turned off wifi.
Uninstalled the 2nd entry then uninstall the first.
