Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Unknow PCI Device - Peripherique Inconnu - D975XBX2
Community Manager
I install my new motherboard D975XBX2 (secondhand) with all drivers.
Fresh install of windows but one device is unknown ?
unknown / PCI Device
Operating system Windows Xp pro SP3 with this component:
INF_allOS_9.1.1.1015_PV.exe
PROXP_v14_2.exe
STOR_allOS_8.9.0.1023_PV.exe
+interna audio card disable (remplace by creative)
+nvidia drivers
Accuracy, on the first boot after install, a "serial port" was detect (AMT - SOL with the software "unknown device" http://www.halfdone.com/Development/UnknownDevices/ ) and i had desactivate in AMT console "Option Management/AMT in bios"
No driver AMT for D975XBX2 in download center intel
Anyone have an idea ?
Bonjour,
j'ai installé ma nouvelle carte mère D975XBX2 (occasion) avec tous les drivers.
Nouvelle installation de windows mais 1 peripherique reste inconnu ?
inconnu / PCI Device
Système d'exploitation Windows Xp pro SP3 avec les éléments suivants:
PROXP_v14_2.exe
+carte audio interne desactivé (remplacé par une creative)
+pilotes nvidia
Précision, suite au premier redemarrage un "Port serie" à été détecté (AMT - SOL avec le logiciel "unknown device" http://www.halfdone.com/Development/UnknownDevices/ ) puis je l'ai désactivé dans le bios AMT "Option Management/AMT in bios"
Aucun driver AMT n'existe pour la D975XBX2
Si quelqu'un a une idée ?
Community Manager
Make sure to have the latest bios version 2838.
As you can see from the bios release notes that there was a fix for a yellow bang as well.
http://downloadmirror.intel.com/16896/eng/BX2_2838_ReleaseNotes.pdf http://downloadmirror.intel.com/16896/eng/BX2_2838_ReleaseNotes.pdf
1. Reboot system.
2. During POST, press F2 to Enter the BIOS Setup Utility.
3. Go to Power >> Disable Intel ® Quick Resume Technology.
4. Press F10 to save and exit from BIOS.
5. Check the Device Manager if the yellow bang is still there.
If it does not fix the problem, remove the sound card just to check whether the yellow bang is from the sound card or not.
If it is due to the external sound card, you will need to look for the correct driver for the card.
If it is not due to the external sound card, try to update the OS and see if it makes any difference and installs all the Intel Driver from the website for the board D975XBX2.
Then install the TPM driver as well, then restart the system and disable tpm in the bios. Try to update the windows as well.
Let us know how it goes. In your next post, add a screenshot showing the yellow bang device id, it may help us possibly.
Note: this is not an amt board - so there is no need to install amt sol driver.
All the best,
Aryan
Community Manager
Thank for this quick answer !!!
* I have AMT in the bios :-) i had desactivate SOL in the AMT menu, after reboot the "serial port" disappear in windows. For testing purpose I had active TCP/IP and smallbuisness mode in AMT menu and connect web page of AMT !!!
wikipedia information:
Intel AMT 1.0 – Intel platforms based on the Intel 82573E (Tekoa; usually 945, ICH7) http://en.wikipedia.org/wiki/Gigabit_Ethernet Gigabit Ethernet Controller, e.g., the Intel D975XBX2 motherboard. This version provides basic http://en.wikipedia.org/wiki/Non-volatile_random_access_memory NVRAM, hardware asset, event log and other basic features. It does not provide Intel System Defense network filters.
* Remember i didn't have "Intel ® Quick Resume Technology" but i will check tonight.
* I will test all other recommendation of you and give news quickly. Thanks and sorry for my poorly english...
Community Manager
hello,
*I don't have "Intel ® Quick Resume Technology" in bios....
*Sound card don't fix the problem....
*TPM don't fix the problem...
*All drivers installed from intel web site... no older version ?
You are sure this mother board is not AMT -SOL ???
http://nowindows.org/public/divers/bugs/D975XBX2.jpg
with SOL activated in AMT menu
http://nowindows.org/public/divers/bugs/D975XBX2_2.jpg
without SOL activated in AMT menu
http://nowindows.org/public/divers/bugs/D975XBX2_3.jpg
Update : http://download.intel.com/support/motherboards/desktop/d975xbx2/sb/d7364501us.pdf
AMT in official documentation !
Community Manager
i had test in maintenance mode (jumper 1-2 > 2-3) and i reset AMT...
not working....
another idea ?
Community Manager
Community Manager
The problem is Solved !!!
The new package PROXP_v14_2.exe not contain AMT driver, version LAN_allOS_14.2_PV_Intel_194152.exe probably it but no link for download ??? why ???
The old 13.5 "http://www.touslesdrivers.com/index.php?v_page=23&v_code=23688"...contain AMT in folder PLATFORM/IntelAMT
The 13.5 version proper installation solved my problem !
Thanks for your help.
Community Manager
I had the same problem. I have the Intel D975XBX2 and Running XP Pro - PCI Device not recognized. I went to the Device Manager and viewed Properties for the PCI Device. Under the Details Tab I found the Hardware ID and googled it. Many results came back about the Marvell RAID Utility. I don't plan to use RAID so I never installed it. So I downloaded the Marvell RAID Driver and rebooted my machine... VOILA Problem solved. Hopefully this helps someone!
