Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
Using ACUConfig from SCS 8.2 on local system board DQ77MK
Community Manager
roI must be missing something simple trying to setup management on one local system. The MEBx is enabled but in full unprovision state with network turned on. Trying to use the ACUConfig utility I get an error and the message in the log is: Error: Host-based configuration is not currently available because the Local Manageability Service (LMS.exe) is not running on the system. What do I need to install/enable/etc. to get the Intel lms service running so the ACUConfig and see my management engine onboard? I was able to use the ACUConfig to create a profile for use with a USB key but I would prefer direct access. Any insight into this would be helpful.
Here a couple of lines from the ACUConfig log.
2013-03-21 03:43:03: Thread:3920(DETAIL) : ACU Configurator , Category: Host Based Setup Discovery Source: Src\ActivatorDll.cpp : GetHostAndMEInfo Line: 3929: Failed to retrieve LMS service status - Skipping Host Based Setup Discovery
2013-03-21 03:43:03: Thread:3920(ERROR) : ACU Configurator , Category: Host Based Setup Discovery Source: Src\ActivatorDll.cpp : GetHostAndMEInfo Line: 3987: Error: Host-based configuration is not currently available because the Local Manageability Service (LMS.exe) is not running on the system.
Overall this board works well especially with the very cool running I7-3770. I was surprise at the size of that package but it runs really cool compared to earlier technologies.
Lee Nelson
Community Manager
https://downloadcenter.intel.com/Detail_Desc.aspx?lang=eng&DwnldID=18531 Download Center
