Intel® Desktop Boards
Peer-to-peer support only
Vccp issue
mv10
i am using the Intel Desktop Board D945GCL since last 10yrs, recently i have found that after about 2 hrs of usage the system Vccp value (seen in Bios) starts fluctuation and at times goes below 0.9 & the system crashes. i have changed the HDD, removed all extra hardware, changed the SMPS & also OS but still its happening.
i would like to know why this is happening & what is the solution ? os is xp sp2
EstebanA_C_Intel
Hello, MV99:
Have you tested the system with a different power supply? or maybe test your PSU looking for possible voltage issues.
You could also take the Motherboard out of the chassis to avoid grounding issues, since this is related to voltage.
Esteban C
n_scott_pearson
Super User Retired Employee
Yes, sounds like power supply is (eventually) overheating...
mv10
yes, EstebanC_Intel i have removed the mobo out & running it outside the chasis on another power supply.
i have also connected another fan so that mobo can be kept cool in case of any heating somewhere.
EstebanA_C_Intel
Hello, MV99:
If the motherboard was removed from the chassis and another PSU was tested, I would go with a possible bad motherboard, unfortunately, chances are that your partner is faulty.
Esteban C
