Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
Viglen DQ67SW latest BIOS driver?
AMG
Hey guys,
I think the title is self explanatory...
Any idea where I could find the latest BIOS drivers for a Viglen DQ67SW motherboard?
Cheers,
A.
AlHill
What bios do you currently have?  Provide the entire bios string.
What is Viglen?
[Windows 11 is the new Vista]
AMG
These are all the details the Intel Tool provides:
Version BIOS Date: 10/24/18 13:52:46 Ver: 04.06.04
Date 10/24/2018
Manufacturer Intel Corporation
Model DQ67SW
Version AAG12527-310
AlHill
What Intel tool?
In windows 10, run MSINFO32.  The BIOS string will look something like this example:
BIOS Version/Date          Intel Corp. KCH7710H.86A.0112.2018.1025.1133, 10/25/2018
AMG
I was using the Driver Support Assistant.
Here's the version from MSINFO32:
BIOS Version/Date Intel Corp. SWQ6710H.86A.0070.2018.1024.1352, 24-Oct-18
AlHill
You already have bios 0070, which is that latest/last.
Why do you think you need to update the bios?
AMG
Well, my PC keeps randomly shutting down.
I've checked everything - drivers, malware, power options, temps - everything seems to be fine.
It powers off after 30 minutes to one hour of uptime - didn't really count to see exactly exactly how much.
AlHill
Have you cleaned the heatsink/fan on the processor?
Have you re-applied the thermal paste on the processor?
Have you tried a different power supply?
Let's start with those.
AMG
The temps of the CPU are fine: ~50C
I didn't try another PSU as I don't have one available.
Maybe you can understand something from these logs.
AlHill
What is your processor model number?   MSINFO32 will tell you.
AMG
I don't seem to find exactly the information under that name but here's some information that I've found related to the processor:
Processor Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz, 3301 Mhz, 4 Core(s), 4 Logical Processor(s)
SMBIOS Version 2.6
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer Intel Corporation
BaseBoard Product DQ67SW
BaseBoard Version AAG12527-310
AMG
Some other mentions, maybe this will help:
1. When turning the PC on, sometimes, it resets after one second for once or multiple times until it finally boots up.
2. When powering it off by Shutdown, sometimes, it comes back up after a few seconds
Could this indicate PSU as well or even motherboard?
AMG
n_scott_pearson
Super User Retired Employee
What I also want you to do is go into BIOS Setup and extract the Management Engine Firmware revision. To do this, do the following:
  1. Power on the board.
  2. Immediately, begin pressing the F2 key on your keyboard over and over and over (about once a second). Eventually, you should see the main screen of BIOS Setup appear.
  3. Scroll down to the Additional System Information entry. That title is from memory, so it may not be exactly that. It should be the entry just above the date and time.
  4. Press <enter> to display this scene.
  5. Scroll down to the bottom of the scene. Note that the scene may be longer that will fit on the screen, so keep scrolling until it hits bottom.
  6. The Management Engine firmware version field should now be on the screen. What is it? Take a picture of the screen.
AMG
n_scott_pearson
Well, it's good that the ME is running properly. I would check for failure occurring exactly 30 minutes after powering on. This would be indication that the ME is responsible.
Have you tested your memory? Download and run something like MemTest86 or MemTest86+ that will thoroughly test the memory (the Windows test is useless AFAIAC).
AMG
Ok, I'll test it and come back with a result tomorrow as it's 1AM where I live.
PC has been up for about two hours now.
I'll see if the issue occurs again tomorrow - all I did was update the optional drivers Windows Update offers as I've read that GUID: 331c3b3a-2005-44c2-ac5e-77220c37d6b4 can be caused by drivers.
Cheers,
A
AMG
Ok, so last night it was fine.
Today it's acting up again.
I've ran the system in Safe Mode and the same thing happened. This should mean that, at least 99%, is not a driver issue.
AlHill
You need to try a different power supply.
AMG
Yep, just ordered one 10 minutes ago.
Should arrive tomorrow - got a 650W PSU, I hope that's enough for my old i5, one SSD, one HDD and the 1050gtx.
http://www.pc-specs.com/psu/Njoy/Njoy_Woden_650W/2500
n_scott_pearson
Have you used MemTest86/MemTest86+ to test your memory? Those resets you hear going on during the POST process are typically caused by an inability to initialize the memory.
