Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
W2600CR W/S board with i350 2xGBE NiC configuration problems IPV4/IPV6
Community Manager
All.
I am having problems with an Intel W2600CR W/S MoBo. Or more exactly, the NIC on the MoBo.
The OnBoard NIC is an I350 Dual Ethernet GbE interface.
We are running W7 x64 Enterprise. The machine has 2* Xeon E5-2620 (6 cores) and 132 GB RAM.
Latest updates from MS. All Intel drivers are up to date as of Oct. 30, 2012.
We are using this computer for remote simulations in ANSYS (Mechanical/Structural analysis) and
the problem is that the remote simulation manager in this WorkStation cannot communicate with the job submitting
machines.
As we tried to troubleshoot, we found out that unless IPV6 was enabled, the NIC would not
let IPV4 traffic pass through. We simply looses all internet connectivity
And the IPV6 messes things up with Ansys Remote Simulation Manager.
My own computer, an HP Z210 can have IPV6 disabled without any similar problem.
I have browsed through the tabs in the NIC properties in the Hardware Manager Tree and found no
clue to why this is happening. I can find no setting that (at least as far as I know) would rectify the problem.
We really need to shut down IPV6 functionality so if there's anyone from Intel out there, I am listening...
Community Manager
I am answering this question myself:
Turning off one of the NIC ports in BIOS confuses W7 device manager. Or, it confuses the driver software. The problem was solved by enabling both ports in BIOS, and the disabling the unused port in W7. This made the remote simulation manager work as intended.
Community Manager
