Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11461 Discussions
Wake On LAN not working anymore on 5599 BIOS update - DX58SO
Community Manager
Hi guys,
After recently updating a very old firmware on my BIOS (the last version dated from 2010), I am now unable to wake my computer up on LAN. So I though the option was automatically disabled during the update process, then I checked the options in the BIOS settings and everything was like it was before. Wake On LAN is enabled under the BIOS settings, but it doesn't work at all.
My question is, is this a known issue? And also, if there's no fix for now, can I downgrade to a workable version?
Thanks!
Dave
Community Manager
I have the same problem, but my DX58SO ta worse, n can update or make any modification, always in default or downgrade anymore. I'm desperate. watchdog has something to do with it? detail until I changed the battery
JRamf
i'm also with this damn problem
DArce
Valued Contributor III
Please bear in mind that this product will be reaching its End of Interactive Support at the end of June,2013 so Intel will no longer provide interactive support for this product via telephone, chat or e-mail, and no further drivers or BIOS updates would be released. For more information please check this article:
http://www.intel.com/support/motherboards/desktop/sb/CS-034322.htm http://www.intel.com/support/motherboards/desktop/sb/CS-034322.htm
In this case, you may need to use an older version of the BIOS if you are having Wake on LAN issues.
Previous BIOS and drivers are posted at:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine... https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine...
Still, be sure that I will forward this information for any further consideration.
