I bought back 5 3T hard drive ready to set up in the P55 RAID5, encountered the following problems.
1.intel RAID interface Each hard disk only recognizes 746.5G
2. After setting up the RAID in the operating system in the hard disk is still a single run (tried RAID0 and RAID5)
3. After setting RAID5, the array state is always (initialize)
Who knows how much capacity the P55 RAID mode supports a single hard drive is the largest
我买回来5块 3T的硬盘 准备在P55上组建RAID5,遇到了以下问题。
1.intel RAID 界面每个硬盘只识别 746.5G (操作系统中能全部识别2.7T)
2.设置完成RAID后在操作系统中硬盘依然是单个运行的(尝试过RAID0和RAID5)
3.设置完RAID5后,阵列状态一直是 (initialize)
谁知道P55 RAID模式支持单个硬盘最大是多少容量
Hhmmm... Have you tried this with UEFI enabled?
emmm...The MSI P55-GD85 does not seem to support UEFI.
Today I try to use 2T hard drive, it works fine. So the P55 RAID mode does not support 3T hard drive
Yea, that jives with my recollection. Unfortunately, I donated my Intel DP55KG-based system (which did have UEFI support in its BIOS) to a charity some time ago, so I cannot verify whether enabling UEFI would have supported the use of larger drives.
