Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
What to do? I accidentally disabled by video output in bios. Now my screen remains blank and no input to the monitor I don't have any graphics card external.
User1584045726645454
AlHill
What is the model number of your Intel Desktop Board?
If you do not have one, contact the manufacturer of your board, and ask them how to reset their bios.
Doc
E210882
i3-4100​
I tried resetting bios but no use.​
AlHill
"E210882" is not the model number of an Intel Desktop Board. Ptovide the model number or AA number, which are on the board.
Doc
AlHill
First, remove that phone number. This is a community forum.
If you have any add-on graphics card, remove it. Plug your monitor into one of the graphics ports on the motherboard. Try booting. Did you see a screen?
If not, try this:
I know you are not having a password problem. But, follow the instructions here and move the yellow jumper as pictured to pins 2-3.
https://www.intel.com/content/www/us/en/support/articles/000005690/boards-and-kits/desktop-boards.ht...
When you boot, you should see the maintenance menu. Reset your video settings. F10.
Doc
Actually i don't have any add in graphics card. if i change the to 2-3 or 1-2 two beep sound and normal boot with no video.if i remove jumper
it shows me the image given below. please help me.
AlHill
Ok, with the jumper replaced on pins 1-2, boot your system and immediately start hitting F2.
Do you see the bios screen?
Doc
no
but a starting sound hears but no display tried blind key pressing. No use.
AlHill
Ok, let's completely clear the CMOS:
  • disconnecting AC power
  • Remove the battery.
  • Wait a full 15 minutes or more
  • Install the battery
  • connect AC power
  • Try booting.
Doc
no,Bios is not displaying
i am getting bios only if battery and jumper removed.
n_scott_pearson
Super User Retired Employee
If you can get into BIOS Setup (Visual BIOS), use the F9 key to reset the BIOS configuration.
