Hello, i have a DH61BR motherboard. with a i3 2100 and a Gigabyte 750TI 1GB, the problem is that the motherboard is Incompatible with this card and will not "see" the gpu, and in bios always the PCI-e says "Not populated" but in reality me friend plug hes GTX 750 TI from zotac and just works! and my card works in another motherboard so its a compatibility problem, me card is a newer version than of my friend. and diggin in internet and forums i fond a guy with the same problem but in a RX480 and he says that a Bios update fixed the problem. my bios is a
BEH6110H.86A i found several link in Intel site, but all are broken because of the driver wipe, so can someone send me a newer vension of this particular motherboard? the version is BEH6110H.86A.0020.2011.0218.1538 From 02/18/2011 anithing newer than that and i will be happy
Sorry for me bad english its not me native language
The links are not broken. Read the announcement on this forum: https://forums.intel.com/s/topic/0TO0P00000018NEWAY/desktop-boards
Doc
so, i make more research and find that me motherboard is in reality a DH61CR-BR so, DH61CR Bios gonna work, the problem is, no more links to bios in intel site, can pls someone help me ? me bios is in version 0020 and i need to upgrade it to 0099 and furthermore 0120 (latest)
It does not matter what your board model number is. Intel has discontinued support for these board, and has removed all bios and driver files as the announcement states.
Doc
...And you need multiple versions of the the BE BIOS in order to make any progress. I can provide you with the latest BE BIOS, but attempting to just install this - even via the BIOS Recovery process - will likely brick your board. You are correct that you need multiple versions of the BIOS to perform this upgrade. Multiple versions are necessary to get you through and beyond the installation of support for 3rd generation Core processors. It is the ME firmware that needs to be updated incrementally in order to accomplish this and these incremental firmware releases are distributed as part of the BIOS update files.
I am checking into getting the necessary files out of Intel. I will let you know - but feel free to ping me if you haven't heard from me in a few weeks.
Hello, i would like to know if you got the files for the Bio update of the Intel DH61CR.
I am looking everywhere for thesse files but can't find then. I have a desktop with this maimboard. I bought a memory card DDR3 1.333MHz 8GB RAM. But the system does not recognize it. I was wondering if it was a problem with the Bios. I never updated it, the version i have is the 0020.
Lucas,
The DH61CR board, like the DH61BR, DH61DL, DH61SA, DH61WW and DH61ZE boards, utilizes the same BIOS files as the DH61BE board.
I have attached a package that includes all of the DH61BE board BIOS update files that you might need. It is important that you follow the instructions provided in the Release Notes (BE0120.PDF) file. If you have any questions, just let me know.
Thanks, you're a lifesaver. I'll folllow the instructions to the letter.
I forgot to mention: Another datapoint: I am using NVIDIA's own GeForce GTX 750 Ti card in my DZ68ZV system.
Sorry for the late response, i find the BE bios in another site, and have successful upgrading all version of the bios, just need to start with version 34,41,44, after this just put the bicked 99 and use the recovery to upgrade to 116 and finally 120 and now my GTX 750 Ti is Working ! but thankyu for your time sr.
amigo, voce poderia me dizer em que site encontrou as bios? muito obrigado
https://de.pcdrivers.guru/intel-desktop-board-dh61cr/download-618797.html.
Cara esse sitem tem todas as Bios.
It is not recommended to use 3rd party download sites, and they should be avoided at all costs.
Doc
Try https://drivers.softpedia.com/get/BIOS/Intel/
The above link is provided for your convenience and the risks are yours.
Doc
Same problem would be the same answer, correct?
What is your problem? Describe in detail.
Doc
Hello, I have the same motherboard, I am currently using 2gb of ram. from a search on the board support and it accepts 16gb of ram, but I open the manual and says that to work it needs to be with stored bios. in my bios this version BEH6110H.86A.0044.2012.0531.1710. Or do you have any way of knowing if my 8gb ram can work.
There are multiple board model numbers in this thread. State which board model number you have, and how much memory you have, and what the density of each memory stick is.
Doc
I understand a memory of 8gb, I wonder if it will work
