Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Which driver about using PC at home?
Jump to solution
Hi, everyone
I want to update the driver of Intel B460 chipset, but I don't know which drivers meet my need.
My CPU is Intel core i5-10400, mother board chipset is B460,
monitor is connected with independent display card,
hard drives are a SATA3 SSD and a SATA3 HDD.
The information of devices are such as the pictures as attached.
My PC is only used at home, no raid and no other device need to manage.
I only use a mouse and keyboard to input words and control UI.
The softwares that I confused are as following.
1. Intel Management Engine Firmware.
2. Intel Serial I/O driver.
3. Intel Graphic Driver.
Q1. Would you please tell me which drivers can meet my need?
Thanks a lot.
Accepted Solutions
Highlighted
The management engine should be installed.
The serial i/o driver should be installed.
The intel graphics?  Probably not, as it is likely disabled by you have an invidia card installed.
You do have IDSA installed, correct?
https://www.intel.com/content/www/us/en/support/detect.html
And, if you update to Windows 10 20H2, Windows Update will help keep your drivers updated.
Highlighted
The information you provided from IDSA indicates that your drivers are up-to-date.  There are no "home" drivers.
Highlighted
Thanks, AlHill.
Therefore, my home using pc don't need the drivers as following. Right?
Highlighted
Highlighted
IDSA said no updates need to install.
Thanks a lot, AlHill.
