Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Which driver about using PC at home?
shiwan0804
Hi, everyone
I want to update the driver of Intel B460 chipset, but I don't know which drivers meet my need.
My CPU is Intel core i5-10400, mother board chipset is B460,
monitor is connected with independent display card,
hard drives are a SATA3 SSD and a SATA3 HDD.
The information of devices are such as the pictures as attached.
My PC is only used at home, no raid and no other device need to manage.
I only use a mouse and keyboard to input words and control UI.
The softwares that I confused are as following.
1. Intel Management Engine Firmware.
2. Intel Serial I/O driver.
3. Intel Graphic Driver.
Q1. Would you please tell me which drivers can meet my need?
Thanks a lot.
AlHill
The management engine should be installed.
The serial i/o driver should be installed.
The intel graphics?  Probably not, as it is likely disabled by you have an invidia card installed.
You do have IDSA installed, correct?
https://www.intel.com/content/www/us/en/support/detect.html
And, if you update to Windows 10 20H2, Windows Update will help keep your drivers updated.
AlHill
The information you provided from IDSA indicates that your drivers are up-to-date.  There are no "home" drivers.
shiwan0804
Thanks, AlHill.
Therefore, my home using pc don't need the drivers as following. Right?
AlHill
shiwan0804
IDSA said no updates need to install.
Thanks a lot, AlHill.
