Intel® Desktop Boards
Peer-to-peer support only
11476 Discussions
Why can't I get the audio driver to install?
MFray1
I've asked this question before and thought I fixed it, but the problem returned.
I have an Intel desktop board model # D510MO. Board number is AAE76523-404. It's running Windows 7 Ultimate 32 bit. I can't install sound drivers on it. The Intel driver update utility doesn't produce anything. I've downloaded the correct drivers from Intel download, but they don't work. It goes through the installation process, reboots, then there's no audio device installed. I've installed the chipset driver and updated the bios.This is the page I got my instructions from: http://www.intel.com/support/motherboards/desktop/sb/CS-034207.htm Desktop Boards — Audio Drivers Do Not Install. I've done this several times.
[Correct Answer by Mark Fraylick on Feb 23, 2015 3:21 PM
I finally got it. I disabled audio in the bios. Then reinstalled windows. I enabled audio in bios and installed the driver.]
This worked one time. On the next reboot, the problem was back. There's no audio device installed. I've since done it twice more the same results.
Mark Fraylick
Silvia_L_Intel1
Mark, we are going to continue helping you on the following thread
