Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
Why would DH67GD hang at POST Code BA after adding more memory?
Community Manager
I have an Intel MOB DH67GD with an Intel i5-2500K processor. I originally had 8GB of memory, (Kingston KHX1600C903K2/8GX), installed and was running Windows 8 with no problems. I decided to increase the memory by an additional 16GB, (Kingston KHX1600C10D3B1K2/16G). The 8GB sticks were in DIMMs 1 and 2 and the 4GB sticks were in DIMMs 3 and 4 per the Intel's recommendation for dual channel operation. The board booted into the BIOS and stopped at POST Code BA. I could not get ti to move any further with any of the function buttons. I then switched the jumper to maintenance mode and the same thing happened. Removing the two 4GB sticks allows the BIOS to complete showing a POST Code of EB. The board runs fine with just the two 8GB sticks. When it hangs at POST Code BA, the LED Shows one steady green light, with no beep codes, the same as a normal completion. My BIOS revision is BLH6710H.86A.156. My board revision is not high enough to go to the BIOS for third generation CPU's. Any help would be appreciated.
I went back and really studied the pictures on Intel's page for Desktop Boards and multichannel memory and finally discovered that although they don't say it in words, the smaller capacity sticks need to be in the first DIMMs. I did that and all works well now. I guess my inexperience shows.&# 13; &# 13; Message was edited by: Franklin Siegrist
RRamo7
New Contributor III
Hi Franklin,
Perfect!, so it's working now since you moved the 4 GBs memory sticks to the blue slots and installed the 8 GBs memory sticks in the black slots.
You are right, accessing that link:
http://www.intel.com/support/motherboards/desktop/sb/CS-011965.htm?wapkw=memory+dual+channel Desktop Boards — Single- and multi-channel memory modes, you can notice that in the image as an example the smaller memory sticks are in the blue slots and the bigger memory sticks are in the black slots.
Thanks for you feedback!
RRamo7
New Contributor III
Hi Franklin,
Community Manager
Thanks for the response. The sticks are working fine, now.
Frank
Community Manager
Hello Frank,
If you experience a similar issue again and if the memory is properly placed, you can test each memory module individually and ensure the power supply is sufficient for the configuration you are looking for.
