Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Will this Intel DG41WV motherboard How to set the BIOS USB boot?
消息编辑者为:9331
消息编辑者为:9331
Tags (1)
Highlighted
Community Manager
Re: Will this Intel DG41WV motherboard How to set the BIOS USB boot?
In order to provide accurate assistance on your inquiry please write your post in English language.
Highlighted
Community Manager
it is likely that he wonders how to boot from a USB device with DG41WV
Highlighted
Community Manager
Press F2 to enter the BIOS set up menu then go to the boot tab and enable USB boot.
Highlighted
Community Manager
Hi I recently baught the DG41WV mother board and i have done a whole operating system install
but once the instelation has completed it wont boot up into the os all it shows is
once you have passed the intel bios screen "-" this appears, i have made sure that the only device to boot from is my hard drive.
How to figure out this problem.
Highlighted
Valued Contributor II
That's the correct setting you already have pictured in your BIOS and as long as you have a bootable USB drive plugged into the one of the boards USB ports, it should boot from it. This works a treat on my DG45ID using a 256 MB USB thumbdrive with DOS on it (useful for running the HDD manufacturers DOS Utility and firmware flashes etc).
Highlighted
intel dg41wv bios file link
Highlighted
New Contributor II
This is an 8 year old thread. Start a new thread.
Doc
