Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Windows won't start after changing BIOS to "Optimal Default"
Jump to solution
Please help... I have a DP35DP board. In the BIOS, I chose the option of "Load Optimal Defaults", Saved changes then attempted the boot. I now get the "Windows Error Recovery" (black and white) menu. it says "Windows failed to start. A recent hardware or software change might be the cause..." I chose the "Last known good configuration" but that is not working (I'm getting the same error screen). Does anyone have a suggestion to help me get back to where my computer will boot successfully? - at your mercy!
Accepted Solutions
Highlighted
Community Manager
I figured it out.... the wrong hard drive type was selected. I changed it from IDE to AHCI and it booted up.
Highlighted
Community Manager
Highlighted
New Contributor III
Tip: in most cases switching to AHCI gives better harddisk\SSD performance. The following link gives the instructions how to do this without reinstalling windows:
http://tweaks.com/windows/44119/improve-sata-hard-disk-performance-convert-from-ide-to-ahci/ http://tweaks.com/windows/44119/improve-sata-hard-disk-performance-convert-from-ide-to-ahci/
