Hi.
I recently purchased a X540-T2 card and tried installing it in my machine featuring a DP67BG mainboard. However it does not boot and halts with the port 80h code "27" ("Configuring memory"). In another machine the card works just fine. Are there any known issues regarding the combination of motherboard and NIC?
Thanks for your help, Moritz
Hi MoritzK,
Thank you for posting at wired communities. X540-T2 is a server adapter, you may refer to the list of compatible system.
https://ark.intel.com/products/58954/Intel-Ethernet-Converged-Network-Adapter-X540-T2
DP67Bg is a desktop board, I would recommend to check with our board support if the network adapter is compatible or if there is any known issue. I will forward you post to the board support.
wb
