Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
XEON E3-1245V2. What are the differences between BX80637E31245V2 and BX80637E31245V2S
The first processor is "BX...1245V2" the second is "BX...V2S". On the compatible processor table for motherboard DQ77MK is only version "BX...V2". Link: http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DQ77MK http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DQ77MK
Ordering and spec information for E3-1245V2: http://ark.intel.com/products/spec/SR0P9 http://ark.intel.com/products/spec/SR0P9
What are the differences between V2 and V2S ? Can I insert the second wersion "BX...V2S" to DQ77MK ?
Victor
Community Manager
Hello Victor,
We would like to inform you that there is no " E3-1245V2S" reported in our database so the only compatible processor is the Intel(R) Xeon(R) Processor E3-1245V2 so far:
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dq77mk http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dq77mk
We recommend using processors from the "supported processors list" to ensure compatibility and functionality with the board.
Community Manager
Thanks for answer.
I found E3-1245V2 (not V2S) but described with code name "BX80637E1245V2S (with V2S), for example at this distributor: http://www.ab.pl/oferta/intel-xeon-e3-1245v2-3-4ghz-bx80637e31245v2s--p223046.html http://www.ab.pl/oferta/intel-xeon-e3-1245v2-3-4ghz-bx80637e31245v2s--p223046.html
Google found them much more. I think it is original Intel product. In fact, Intel www site not found code name "BX ...V2S".
