reI can not get Intel Extreme Tuning Utility to work every time i start it i get a prompt about that it is unable to start.
Here is the log from XTU called xtucore.
2013/10/02-08:18:58.4342|INFO] *** LOG FILE STARTED ***
2013/10/02-08:18:58.4342|INFO] XtuCore Version 4.2.0.8 - CiBuild:Official - 4.2 PV:4.2.0.8:PF226022:BITHFBMAP001
2013/10/02-08:18:58.6217|INFO] Initializing performance tuning application mutex
2013/10/02-08:18:58.6373|INFO] Mutex initialized and acquisition callback registered
2013/10/02-08:18:58.6373|INFO] Waiting for app mutex event request
2013/10/02-08:18:58.6373|INFO] Attempting to query performance tuning mutex
2013/10/02-08:18:58.6373|INFO] App mutex event Query completed - Result: False
2013/10/02-08:18:58.6373|INFO] Query operation completed - Result: False
2013/10/02-08:18:58.6373|INFO] Attempting to perform Unity Initialization against Library HardwareServices
2013/10/02-08:18:58.6686|INFO] Handling Unity Intialization for HardwareServices->ServicesUnityInitializer->Initialize
2013/10/02-08:18:58.6842|INFO] Validating arguments for library init call for Initialize
2013/10/02-08:18:58.6998|INFO] Initializing DriverWrapper for driver \\.\IOCBIOS2
2013/10/02-08:18:58.6998|INFO] Initializing DriverWrapper for driver \\.\AcpiCtl
2013/10/02-08:18:58.6998|WARN] Could not connect to the ACPI driver
2013/10/02-08:18:58.6998|INFO] Using non-null Lenovo SMI service
2013/10/02-08:18:58.7467|WARN] Could not load the specified SMI stub XML file.
2013/10/02-08:18:58.778|INFO] ACPI Hardware Service Recorder Created and Initialized
2013/10/02-08:18:58.778|INFO] Starting watchdog initialization
2013/10/02-08:18:58.778|INFO] Attempting to connect to true watchdog
2013/10/02-08:18:58.778|INFO] Get driver path called for guid: c2e625a9-8693-4dea-bac4-b15ca98f9ee9
2013/10/02-08:18:58.778|INFO] Device path length: 67
2013/10/02-08:18:58.778|INFO] Device path: \\?\acpi# int3f0d# 4&16f18e0&0# {c2e625a9-8693-4dea-bac4-b15ca98f9ee9}
2013/10/02-08:18:58.778|INFO] Initializing DriverWrapper for driver \\?\acpi# int3f0d# 4&16f18e0&0# {c2e625a9-8693-4dea-bac4-b15ca98f9ee9}
2013/10/02-08:18:58.778|INFO] Attempting to create PCH Watchdog service
2013/10/02-08:18:58.8092|INFO] Attempting to perform Unity Initialization against Library HardwareAccess
2013/10/02-08:18:58.8249|INFO] Handling Unity Intialization for HardwareAccess->AccessUnityInitializer->Initialize
2013/10/02-08:18:58.8405|INFO] Attempting to perform Unity Initialization against Library XtuApplication
2013/10/02-08:18:58.8405|INFO] Handling Unity Intialization for XtuApplication->ApplicationUnityInitializer->Initialize
2013/10/02-08:18:58.9499|INFO] InitializeMsrFields called
2013/10/02-08:18:58.9655|INFO] Read CPU Info for type called: 1
2013/10/02-08:18:58.9655|INFO] Read CPU INfo on MSR Service called for type: 1
2013/10/02-08:18:58.9655|INFO] Couldn't find access token for thread. Impersonating thread to acquire token.
2013/10/02-08:18:58.9811|INFO] CPU Info Id for processor Family Index: 0 Value: 132775
2013/10/02-08:18:58.9811|INFO] CPU Info Id for processor Family Index: 1 Value: 1050624
2013/10/02-08:18:58.9811|INFO] CPU Info Id for processor Family Index: 2 Value: 230351807
2013/10/02-08:18:58.9811|INFO] CPU Info Id for processor Family Index: 3 Value: 3219913727
2013/10/02-08:18:59.0124|!ERR] Invalid MSR read for this processor (SandyBridge): OverclockingLock
2013/10/02-08:18:59.0124|INFO] Read CPU Info for type called: 6
2013/10/02-08:18:59.0124|INFO] Read CPU INfo on MSR Service called for type: 6
2013/10/02-08:18:59.0436|INFO] Initializing Acpi Hardware Access
2013/10/02-08:18:59.0749|INFO] Initializing WMI Based Platform Detection
2013/10/02-08:18:59.0749|INFO] Creating WMI Object Searcher - Namespace = \root\cimv2 Query = "Select HardwareID, DeviceID from Win32_PnPEntity"
2013/10/02-08:18:59.0905|INFO] Search Object Created - Object List Retrieved
2013/10/02-08:18:59.0905|INFO] Searching object list for platform ID
2013/10/02-08:18:59.1061|INFO] Found possible platform ID on system: 262
2013/10/02-08:18:59.1217|INFO] Found possible platform ID on system: 7698
2013/10/02-08:18:59.1217|INFO] Found possible platform ID on system: 7725
2013/10/02-08:18:59.1374|INFO] Found possible platform ID on system: 7718
2013/10/02-08:18:59.153|INFO] Found possible platform ID on system: 7712
2013/10/02-08:18:59.153|INFO] Found possible platform ID on system: 7683
2013/10/02-08:18:59.153|INFO] Found possible platform ID on system: 7775
2013/10/02-08:18:59.153|INFO] Found possible platform ID on system: 7738
2013/10/02-08:18:59.153|INFO] Found possible platform ID on system: 7696
2013/10/02-08:18:59.153|INFO] Found possible platform ID on system: 7714
2013/10/02-08:18:59.153|INFO] Found possible platform ID on system: 260
2013/10/02-08:18:59.153|INFO] Found 11 possible Platform ID(s)
2013/10/02-08:18:59.1686|INFO] Failed to match device ID with list of supported platforms.
2013/10/02-08:18:59.1686|INFO] Successfully matched device ID to list of supported platforms: SandyBridge
2013/10/02-08:18:59.1686|INFO] Searching object list for integrated graphics devices
2013/10/02-08:18:59.1686|INFO] Platform detection found integrated graphics device
2013/10/02-08:18:59.1999|INFO] Initializing MSR Tuning
2013/10/02-08:18:59.2155|INFO] Initializing MSR Control Mappings
2013/10/02-08:18:59.2155|INFO] Initializing MSR BIOSless Control Map
2013/10/02-08:18:59.2624|INFO] + Added MSR control [0x00000031|TurboPackageTdpShortEnable] (PkgShortWinTdpEnable). Active Value = 1
2013/10/02-08:18:59.2936|INFO] + Added MSR control [0x0000002F|TurboPackageTdpShort] (PkgShortWinTdpLimit). Active Value = 21.250
2013/10/02-08:18:59.3093|INFO] + Added MSR control [0x00000030|TurboPackageTdpExtended] (PkgExtWinTdpLimit). Active Value = 17.000
2013/10/02-08:18:59.3093|INFO] + Added MSR control [0x00000032|TurboPackageTdpLock] (PkgTurboPowerLimitLock). Active Value = 1
2013/10/02-08:18:59.3093|INFO] + Added MSR control [0x00000000|MaxNonTurboRatio] (MaxNonTurboRatio). Active Value = 11
2013/10/02-08:18:59.3093|INFO] + Added MSR control [0x00000029|EistEnable] (EistEnable). Active Value = 1
2013/10/02-08:18:59.3093|INFO] + Added MSR control [0x0000001A|TurboModeEnable] (TurboModeDisable). Active Value = 1
2013/10/02-08:18:59.3405|INFO] Initializing ACPI tuning system
2013/10/02-08:18:59.3405|INFO] Initializing auxiliary watchdog flag - Recovery Status: True
2013/10/02-08:18:59.3561|INFO] Initializing Watchdog Timer</...
Would you please provide me the system configuration, including the motherboard, processor, memory and any other device you are using?
In addition to that, please let me know which operating system you have installed on the computer?
Which memory settings are you changing when using the XTU?
