Hi there,
I have a Z68BC with a 2600k and dual 7970s. after shutting down my computer one day, and then turning it back on, windows 7 doesn't see any network adapters in the network and sharing center, and when i try to update my LAN driver, it finishes, but when i go to device manager, it says the device is disabled because the driver is causing issues.
so two issues here:
1: windows doesent see my internet devices(i have a Intel 6300 wifi adapter, and LAN)
2: LAN adapter does update, but in device manager says it cant turn on the driver.
Here are our recommendations for this issue:
- Remove and re-install all drivers from the on-board LAN and the other external LAN adapters you have.
- Make sure you are downloading the latest LAN driver from our website:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22612&lang=eng&OSVersion=Windows%207... Download Center
- Update your motherboard BIOS to latest version 0039:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22159&ProdId=3381&lang=eng&OSVersion... Download Center
- If the issue still persists, proceed with a clean installation of the Operating System using the latest drivers from our website:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine... Download Center
