Intel® Desktop Boards
Peer-to-peer support only
11432 Discussions
actualice la bios de mi board dg35ec y el compu quedo muuuuuuuuuy leeeeeentooooooo, que puedo hacer. Gracias
MMarc22
Buenas noches
En verdad no se que hacer, estoy desesperado por la lentitud y eso que estaba funcionando super con un disco SSD, pero al actualizar la bios, todo se fue al traste. Gracias por sus ayudas
n_scott_pearson
Super User Retired Employee
If I understand correctly, you updated your BIOS and the computer is running slow. I suggest that you do the following:
  1. Unplug the system from A/C power.
  2. Remove CR2032 battery from board.
  3. Wait 15 minutes.
  4. Restore the battery.
  5. Restore power and boot up.
  6. Press F2 to enter BIOS Setup.
  7. Press F9 to restore the default BIOS configuration.
  8. Make any changes to BIOS Setup that are necessary for your hardware configuration (boot order, etc.).
  9. Exit BIOS Setup saving the configuration.
  10. Boot up into your O/S (Windows, Linux, whatever) and check if the problem is alleviated.
Hope this helps,
Community Manager
Hi Mafore,
I am following up on your case. Let me know if I can help you with anything else.
Mike C
