Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
after update bios have aa error how can fix it?
amoha22
mb: dx79t0
version : G28805-400
s/n : BTTO2060001p
after update bios i have aa error
how can fix that?
please help me 6344.ali@gmail.com
n_scott_pearson
Super User Retired Employee
This could be a simple issue or major trouble. I suggest that you first unplug the system (from the wall) and remove the CR2032 battery from the board for 15 minutes. This may get it going. If it doesn't, try reinstalling this same BIOS, but do so via the recovery method...
amoha22
Hi
Don't fix with remove battery for 15 min
Please help me who can fix them
What this way ? (do so via the recovery method... )
Than for help me
amoha22
My country is denied
It is impossible for me to buy a new one
Please help me solve the problem grow up
Thank you
n_scott_pearson
Review this article for information on the BIOS recovery process: http://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html?wapkw=bios+recovery Recovery BIOS Update Instructions for Intel Desktop Boards.
amoha22
Don't let download Recovery BIOS file
I need recovery main file for
Dx79t0
Version G28805-400
S/N BTTO2060001P
need one file resolve my aa number
Than for help me
n_scott_pearson
There is no "recovery" BIOS, per se. Here are the instructions to follow:
  1. Reformat a USB 2.0 flash disk using the FAT32 file system. [Important: do not use USB 3.0 flash disk]
  2. Download the .BIO file for the latest available TO BIOS and copy it onto the flash disk. [Important: this should be the only file on the flash disk]
  3. Power off X79 system and remove the (yellow) BIOS Configuration jumper.
  4. Plug the USB flash disk into one of the (black) USB 2.0 ports on the back panel of the TO board. [Important: do not use (blue) USB 3.0 port]
  5. Power on the system.
The system should proceed to load the updated BIOS and install it. You should see its progress detailed on-screen (just as it would during a normal BIOS update). When it is complete, you will see a message telling you to power off and replace the jumper. Do so. When you power back up (hopefully without seeing the AA error), use F2 to enter BIOS Setup and then F9 to restore BIOS configuration defaults. You can then customize the configuration as necessary for your peripherals and OS.
If your screen remains blank the and BIOS recovery does not seem to start, wait at least 15 minutes before giving up and powering the system off.
If the process failed to work or the AA error remains, you may be out of luck. Under normal circumstances, if the AA number is lost, this is not something that can be fixed in the field. Special tools (only available inside Intel) are necessary to restore it.
Good luck,
...Scott
amoha22
When I remove jumper do error b2 and my monitor don't show any thing
U have one back up of my model bios ?
I need main back up( bios file)
amoha22
And with this system can use this vga ?
Giga R9 390 G1
n_scott_pearson
No, there is no way to do a "backup" like this. An image of the flash would contain system-specific information -- MAC address, Board's Serial Number, etc. that you (similarly) would not be able to change (because of the BIOS security in place). Two systems should not share a MAC address or Serial Number...
Usually, corruption of the flash, serious enough to wipe out the AA number, is the result of an aborted flash update (people are told not to power off during an update for good reason). I am not saying that you did anything wrong; what I am saying is that there is usually no recovery from this state. Your only hope may be in having this board replaced by Intel - presuming that it was purchased legitimately and is within the 3 year warranty period...
The older a board is, the more chance that there could be an incompatibility issues with newer video cards. I am disappointed that one this recent could be having this issue, but there have been a couple of reports of issues with these cards and other 7 Series boards. In some cases -- unfortunately not you with this AA error -- you can ignore the issue and still boot into Windows and use the card (you just cannot enter BIOS setup with this incompatibility). In other cases, this card is simply incompatible and there is nothing you can do about it (other than update to the latest available BIOS and hope that this resolves the incompatibility)...
Sorry I didn't have better news...
amoha22
1 pic I upload
See my main haven't model
My problem is this
n_scott_pearson
Are you talking about the picture now attached to the original posting? According to this picture, you do not have an AA error. The strings that are supposed to be there are there. So what is your problem?
amoha22
I upload 3 pic
One pic at power on pc (aa number error .will use enter to skip that )
Tow pic at bios option f2 key ( haven't desktop board option )
TREE PIC at windows (when want install driver cd dp this error )
and my Lan and sound don't work and vga have problem
Can fix this problem ?
n_scott_pearson
Use F2 to enter BIOS Setup. Then, use F9 and then Y to reset the board's configuration to defaults. Then, scroll down and select "Additional System Information". Take a picture of what's on the screen. Now scroll down to the bottom of the scene. Take another picture. include these pictures in your response.
amoha22
After reset to difult I see pic 1 and 2
Pic name : 1 and 2
I can't send email because my country is block
n_scott_pearson
This system has its Board Information incorrectly placed into its System Information structure. It is also missing its MAC address. I am afraid you are not going to be successful doing anything with it...
Sorry,
Community Manager
Hello:
ali6344, this an issue related to the BIOS and chipset, normally we would replace the motherboard, but in this case this product is End of Interactive Support and unfortunately, there is no warranty for this.
Amy.
