Community
cancel
Showing results for
Search instead for
Did you mean:
MDehn
are the SATA connectors on the DP45SG compatible with a SSD SATA III drive
Jump to solution
I have a DP45SG MB but cannot tell what SATA classification the connectors interface is. Are the any compatibility issues with using a SSD device such as the Corsair Force Series GS CSSD-F180GBGS-BK 180GB SATA III iSSD?
Tags (2)
Silvia_L_Intel1
Hello Dehnemi,
This motherboard support SATA 2.0 (3 GB/s), therefore it would be necessary to check with the SSD manufacture if it is backward compatible.
Regards.
Silvia_L_Intel1
Hello Dehnemi,
Regards.
