Dear Team.,
I have a intel 61 BF mother board and dual core 3 GEN, after installing windows its working perfectly but when we are trying to install on board display drivers or dedicated graphic card drivers display getting black and not responding.
could you give some resolution.
thanks
rajashekhar
What5 is the exact model number of your board?
Doc
What is the bios version?
What is the processor model number?
Are you legacy boot or UEFI boot?
Doc
Processor Pentinum dual core gen 3
Bios version as stock from 2013
Booting on legacy
That will not do. Boot to the bios and provide the bios revision number.
While you are there, get the processor model number.
Doc
Processor: intel pentinum CPU G2020 @ 2.90Ghz
Bios version : BFH6110H. 86A.0009.2013.0715.1155
The latest graphics driver for your onboard graphics is here:
https://downloadcenter.intel.com/download/29473/Intel-Graphics-Driver-for-Windows-15-33-
Remove the add-on card, and install this driver.
Doc
thanks i will try this and one more any bios update required?
I tried to install that same driver as suggested but still same issue after installing display getting black
Then try different memory.
Doc
Ok, does the screen stay ok until you try to update the driver?
If so, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
W10 2004, W10 May 2020, W10 20H1, W10 19041 - A rose, by any other name, still smells.
