Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
can i where download hm65 chipset driver?
ghaas1
here on the site of intel says there is no driver to download the hm65 chipset. Can I where download
n_scott_pearson
Super User Retired Employee
You can try using the version here: https://downloadcenter.intel.com/download/26807/NUCs-Intel-Chipset-Device-Software-for-Windows-10-fo.... This supports the chipsets through 8 Series and for Windows 7 and 8.1.
I suggest that you use the following procedure (as Administrator):
  1. Extract the downloaded ZIP file to a temporary folder.
  2. Open a Command Prompt.
  3. Make the temporary folder the current directory.
  4. Enter command "SetupChipset -overall".
  5. Reboot after it is complete (it should prompt you to do so).
Hope this helps,
AlHill
What device? Laptop or desktop? What manufacturer and what model?
What operating system? What version? 1809?
Doc
ghaas1
good night. Good night guys. It's a laptop. Manufacturer is cce, model wm545b. More using the hwinfo program it says it's motherboard is INTEL Corporation HURONRIVER. And the windows dxdiag tool says it is manufacturer standard and model ahv. I am using windows 8.1 64-bit version 6.3 build 9600.
n_scott_pearson
Hope this helps,
ghaas1
thank you. helped me
