Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
cannot upgrade to Windows 8 on DB75EN
Community Manager
I don't know if this is related to the motherboard but it is the closest place to ask I can think of.
I do have the following configuration:
Intel Desktop Board DB75EN - updated to the latest BIOS from the Intel's website
Intel Core i5-3470 Processor
Corsair Vengeance - 32 GB Quad Channel DDR3 Memory Kit (CMZ32GX3M4X1600C10)
Intel SSD 520 series 240 GB disk drive
a Chieftec 350 W power source
running on the HD2500 integrated video
I had installed my Windows 7 Home Premium 64-bit which was running very stable and smooth. But because Home Premium Edition is limited to 16 GB of memory I have though to purchase the upgrade to Windows 8 Pro, an upgrade which is part of a special offer. Windows 8 Pro seems to support up to 192 GB of memory.
The problem is that the upgrade fails. Windows 8 cannot boot correctly. After installation the booting process just hangs. I think it is related to this UEFI boot procedure. Is this a known issue? Does this motherboard support Windows 8? Or is it too early to ask? Are there any special settings for the installation of Windows 8? I have read somewhere that somehow the problem can be resolved by enabling the how swap capability of the SSD drive in BIOS. However I tried this too but to no avail.
Also the spinning circle which is the first think to see when Windows 8 is booting is overlapped over the BIOS picture which you can see when booting up on this motherboard. This can be due to the integrated Ivy Bridge video card. Is this a desktop BIOS bug, a CPU bug or a Windows 8 bug?
Community Manager
After a few attempts I have managed to install Windows 8, but the freezing continues. It is freezing exactly as it was freezing during the boot time. I have tried also to disable the dynamic ticking but the computer still freezes randomly. Is this a known issue?
Community Manager
I think I have found the problem, I almost forgot about it and I did not even mentioned it here, I had also a TP-Link TL-WN851ND card in the PCI socket. As soon as I removed the card the installation went flawlessly. It seems that this card is causing Windows 8 freezing. If someone encounters Windows 8 freezing it should try to remove any Wi-Fi adapter and see how it goes. Looks like a Windows bug, as the OS should not hang.
