Intel® Desktop Boards
Peer-to-peer support only
co mam zrobic
pkuzm
Moja plyta glowna Intel corp dh 55 tc mam 2x2 giga Ramu ale kupilem 4x4 giga Ramu Parametry sa te same dysk ssd , grafika goforce 1030 2 giga, wlozylem te 4 i system sie restartuje caly czas co mam zrobic prosze o pomoc i mój mail na piotek.k93@gmail
Zapytanie: moja plyta glówna to intel corp dh 55 tc mam 2x2 giga ramu ale kupilem 4x4 giga Ramu parametrów sa te same dysk ssd, grafika goforce 1030 2 giga, wlozylem te 4 i system sie restartuje caly czas co mam zrobic prosze o pomoc ted34g1333c9bk 4 giga ddr3 1333 cl 9-9-9-24 1.5 v team group
AlHill
It is possible you have bad memory.
Or, you may need to update your bios. Do you know what bios version you have?
Doc
AlHill
I have attached the latest bios for you.
Doc
LeonWaksman
Hello @pkuzm​
Insert only one RAM module at time. Start with one module, then add the second one, next the third and finally the fourth one. If during this test you will find a module, that causes the computer reboot, don't use it, probably this is fault memory module.
Leon
