Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
controlador AHCI para integrar en instalacion nueva de win xp profecional 32 bit placa DG35EC
RLant1
Agradecería a quien/es pudiera/n ayudarme a conseguir los controladores y/o driver AHCI, para integrarlo en un instalación nueva de win xp profesional 32 BIT, y de esta manera poder configurar la bios en AHCI, para que pueda identificar los discos sata, ssd, agrego todos los datos de que dispongo, que son:
MODELO DE PLACA:DG35EC
System BIOS: ECG3510M.86A.0084.2008.0523.1528
System Product: DG35EC
Graphics Information: Intel(R) G35 Express Chipset Family
Processor Name: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Processor Information: x86 Family 6 Model 15 Stepping 11
Detected Chipset:
Intel(R) 946GZ Express Chipset
Chipset Components
Memory Controller:
82946GZ
I/O Controller:
Intel(R) 82801HB/HR I/O controller hub (ICH8/ICH8R) SATA Controller found in IDE mode
Integrated Graphics:
Intel(R) 82946GZ Graphics and Memory Controller Hub (GMCH)
AlHill
There are no AHCI drivers for XP.
XP support ceased 3 years ago.
Your board is nine years old and no longer supported: http://ark.intel.com/products/34689/Intel-Desktop-Board-DG35EC Intel® Desktop Board DG35EC Product Specifications
What drivers and downloads there are for your board can be found here: https://downloadcenter.intel.com/product/34689/Intel-Desktop-Board-DG35EC Downloads for Intel® Desktop Board DG35EC
If you insist upon running XP, you may want to try running in "XP MODE" as a virtual machine on Windows 7, for example.
As a last resort, you may want to try and find a version of Matrix Storage Manager or Intel Rapid Storage for XP, which may provide AHCI support. For this option, I am just guessing.
Doc
Community Manager
Hi RickydeMadryn,
I understand you are looking for AHCI drivers for the motherboard model DG35EC.
At this stage, I would like to confirm if you are currently running an Intel® board DG35EC with Intel® chipset G35 (ICH7) or the Intel® chipset 945GZ with ICH8R. Please run the following utility and attach the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility
In order to attach files, make sure you select the "Advanced Editor" option in the top right of your reply window. You will then be presented with an attach file dialogue at the bottom of the reply.
Please bear in mind this community forum is only available in English. Please try using translator if you need further information.
Allan.
Community Manager
Hi RickydeMadryn,
I was wondering if you were able to pull out the system configuration. Do not hesitate to contact us back.
Allan.
