Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
db75en bios supervisor password
SFave
On start up always display a chassis warning and after that a box is displayed on screen asking for a password, with the title "Enter Password To Unlock System". I tried a lot password, "admin" and others that may be used by the owner, with no success.
I´m traiyng to clear that pass without success.
bios jumper, and with Intel® Management Engine BIOS Extension jumper, also.
I upgrade the firmware.
remove the battery too.
what else can I do ?
n_scott_pearson
Super User Retired Employee
Resetting the password is done from the BIOS' maintenance page. This is activated by moving the BIOS Configuration Jumper from the 1-2 pins to the 2-3 pins (while system is powered off!).
SFave
Thank you, but I open a Case with intel, because, I alrready done all that and nothing works.
EstebanA_C_Intel
Hello, SAFtware:
Thank you for your answer on this.
If you require any further information or support, feel free to contact the Intel Communities back.
Esteban C
