Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
dh55pj mother biard problem...
SNeog
Dh55pj mothetboard after imstalling new ram getting problem to updaye 64 bit and Windows is not loading.
Silvia_L_Intel1
Hello Sumit420, thanks for joining the Intel community.
Please let me have the following information from your system:
  • Processor model number:
  • Current BIOS version:
  • RAM model number:
  • Windows Version:
Sumit420, if you install the old memory Ram, are you able to access Windows?
SNeog
My processor model no i3 cpu 530 @ 2.93 ghz
Bios ver TCIBX10H.86A.0037.2010.0614.1712
Ram model no trancend JM1600KLH4G
Windows 7 ultimate..
SNeog
And yes if i install old memory 2 gb ram i am able to access
Silvia_L_Intel1
Sumit420, the reason why the system is not working with the new memory is because the processor supports DDR3 1066/1333 MHz
http://ark.intel.com/products/46472/Intel-Core-i3-530-Processor-4M-Cache-2_93-GHz http://ark.intel.com/products/46472/Intel-Core-i3-530-Processor-4M-Cache-2_93-GHz
The memory you are trying to use supports 1600MHz. So it is not compatible with the processor. It is required to use the correct memory type when using our processors otherwise the warranty won't cover the product.
SNeog
Before i used 1333 mhz ram trancend TS512MLK64V3H but that time also same problem came and time i thought that ram problem and i changed the ram....
Silvia_L_Intel1
You may need to change the RAM, but try to use the correct memory speed on the system.
You can also try to update the BIOS of the board. I would recommend you checking this link https://downloadcenter.intel.com/search?keyword=Intel%C2%AE+Desktop+Board+DH55PJ https://downloadcenter.intel.com/search?keyword=Intel%C2%AE+Desktop+Board+DH55PJ
It will provide you the list of BIOS and drivers available for your motherboard. According to your comments the current BIOS version on the board is 0037, you can try to install a newer version.
I would like to tell you that going straight to the latest version shouldn't be a problem, technically speaking. However based on experience, there is always chance. So I suggest you installing a few versions before updating to the latest version 0048.
ARoja10
I have the same issue with this motherboard, is the same procesador (intel i3 530) try to upgrade the RAM with a kingston KVR13N9S8/4 and windows its not booting (shuts down on after windows logo), the RAM module is 1333 and nothing, i have update the BIOS to the latest and still the problem persist, any ideas!? Please help
IUman
Hello Getand,
Let me ask you the following:
Did you try one RAM at a time on each of the DIMMs?
Do you have enough power supply, or maybe you can try a higher wattage power supply?
Do you know by any chance if this RAM is low profile or high density RAM?
ARoja10
I´ve try the RAM in both slots and boths works fine with the previous module, dont know about the power supply (not my expertise), the ram i asume is a low profile because its very small
http://www.kingston.com/dataSheets/KVR13N9S8_4.pdf http://www.kingston.com/dataSheets/KVR13N9S8_4.pdf
but in the sheet especifications, says (1.425V ~1.575V) same as my previous RAM module
http://www.kingston.com/dataSheets/KVR1333D3N9_2G.pdf http://www.kingston.com/dataSheets/KVR1333D3N9_2G.pdf
any ideas?
IUman
How many GB of RAM did you use with the previous module and how many GB are you installing with the new ones?
Please take a look to the RAM configuration and the tested memories for this motherboard at:
http://www.intel.com/support/motherboards/desktop/dh55pj/sb/CS-031469.htm# dimms http://www.intel.com/support/motherboards/desktop/dh55pj/sb/CS-031469.htm# dimms
If the old RAMs are working fine and the new ones are not, then most likely it could be a compatibility issue.
ARoja10
I have a 2gb of RAM and i've bought this 4gb module,
n_scott_pearson
Super User Retired Employee
I would note that many of the low-profile DIMMs are not supported...
