OS Name Microsoft
Windows 10 Home
Version 10.0.10586
Build 10586
Other OS Description Not
Available
OS Manufacturer Microsoft
Corporation
System Name JITU-PC
System Manufacturer
System Model
System Type x64-based
PC
System SKU
Processor Intel(R)
Core(TM) i3 CPU 540 @ 3.07GHz, 3059 Mhz, 2 Core(s), 4 Logical
Processor(s)
BIOS Version/Date Intel Corp. TCIBX10H.86A.0048.2011.1206.1342, 06-Dec-11
SMBIOS Version 2.6
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer Intel
Corporation
BaseBoard Model Not
Available
BaseBoard Name Base
Board
Platform Role Workstation
Secure Boot State Unsupported
PCR7 Configuration Binding
Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version
= "10.0.10586.589"
User Name jitu-PC\jitu
Time Zone India
Standard Time
Installed Physical Memory (RAM) 2.00 GB
Total Physical Memory 1.86
GB
Available Physical Memory 294
MB
Total Virtual Memory 4.11
GB
Available Virtual Memory 1.88
GB
Page File Space 2.25 GB
Page File C:\pagefile.sys
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
Please suggest me which ram I purchase
This is your processor: http://ark.intel.com/products/46473/Intel-Core-i3-540-Processor-4M-Cache-3_06-GHz Intel® Core™ i3-540 Processor (4M Cache, 3.06 GHz) Specifications
For memory specifications, refer to section 1.1.1 table 1 on page 9 of the technical specification for your board: https://downloadmirror.intel.com/18505/eng/DH55TC_TechProdSpec.pdf https://downloadmirror.intel.com/18505/eng/DH55TC_TechProdSpec.pdf
For 8gb memory, you would probably want to use four 2gb sticks that meet the specifications defined in the above document.
However, you are using Windows 10.
You should note that your board is not supported on Windows 10: http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005640.html Supported Operating Systems for Intel® Desktop Boards
You should also note that your processor is not supported on Windows 10: http://www.intel.com/content/www/us/en/support/processors/000006105.html Intel® Processor Support for Microsoft Windows® 10
And, your onboard graphics are not supported on Windows 10: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products
Doc
Thank you Al Hill and N. Scott Pearson for explaining this information for this customer
Best wishes,
Ivan
Your board can handle two pairs of unbuffered, non-ECC, x8 organized, 5V DDR3 DIMMs. Note the following:
- Recommendation is to use 1066 or (better) 1333 MHz. Faster DIMMs can be used, but problems/incompatibilities may occur.
- Each individual DIMM can be 1, 2 or 4 GB in size. Maximum supported is 16 GB total.
- All four DIMMs should have identical specifications. Though the size of the DIMMs used in one channel may differ from the other, it is best if they are all the same size.
Here is a link to a summary of the general requirements and a list of known-compatible memory: http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005869.html System Memory for Intel Desktop Board DH55TC. This list is pretty old; you will likely need to match available DIMMs against the specifications for the listed DIMMs.
Hope this helps,
