Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
dh61ww flashing
msilv49
here's my problem. I've started updating my bios from 0020 version, until the 0035 one, then I'm stuck. I can't update it anymore, will abort the operation every time.
My goal is to use the i5 3570, I need at least the 0041 version, currently it does not work with it, it throws 3 bip on boot. I use the F7 method, any help would be greatly helpful, thanks.
AlHill
3 beeps is a memory issue. Try removing your memory and using only one stick, until you get past the 3 beeps. You will still have a problem with the bios update, however.
Doc
msilv49
I've used an i3 2120 for the flashing process, together with one stick of 1333mhz ram.
Now i have a new problem. I've tried to return to 0034 and flash again. The motherboard is no longer able to function, it is stuck in a recovery loop, not permitted from bios 0035 to bios 0099...
So, it's not possible to update the bios, from 0020 to 0041?
AlHill
Keep messing with it and you will brick the bios, if not already.
@n.scott.pearson​ may be able to help you out of this jam. Just be patient.
Doc
msilv49
I'll try a recovery procedure, https://www.intel.com/content/www/us/en/support/articles/000005630/boards-and-kits.html
No drama, if the motherboard bricks itself, it's useless without the i5 3570. I've used countless motherboards, from every manufacturer, but this is a intriguing one, nearly as the earlier Msi branded ones!
n_scott_pearson
Super User Retired Employee
Hi @msilv49​,
I defined a process for getting from where you are to where you need to be (namely, BIOS 120 (BE0120)). See my post here for full instructions: https://forums.intel.com/s/question/0D50P00004HIiQ1SAL/unable-to-update-bios-past-0035-dh61cr.
Note that you should complete this entire process using your 2nd gen. processor (the Core i3-2120); you can install your 3rd gen. processor (the Core i5-3570) when the process is complete.
Hope this helps,
P.S. To anyone else reading this post: This process applies equally well to any of these boards: DH61CR, DH61BE, DH61DL, DH61SA, DH61WW and DH61ZE. All of these boards utilize the same BIOS.
msilv49
Hi, I've followed these instructions and it does not work.
"Recovery is not permitted from BIOS 0035 to BIOS 0041"
Do i need to use the 0035 BIOS to recover?
n_scott_pearson
I have never seen that message before. Can you try again and take a snapshot of screen (using phone)?
Y​es, a possible scenario is to do recovery to BIOS 35 and then install BIOS 41 and BIOS 48 using F7 method.
