Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
dh77eb and ASUS gtx 760
SRed
After insallation the video card ASUS gtx 760 stopped working built-in sound card. Moreover, the system displays it as work, but there is no sound from the speakers. After removal of the video sound does not work.
Silvia_L_Intel1
Hello SergRed, thanks for joining the Intel Community.
The cause of this behavior could be that the motherboard is still recognizing the video card as the output video.
I would recommend you to do a clear CMOS by removing the CMOS battery from the board for about an hour.
You can also run default setting on BIOS by pressing F9 key.
Try also to select the NVIDIA high definition audio as your default audio source.
