Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
dh87RL board raid compatible hdd needed
cseka
i m planning to use dh87RL board & i want to enable RAID0 ARRAY BY USING 3 HARD DISK. I NEED HDD capacity 750 gb only. kindly suggest me the best sata hdd which will work perfectly with raid0
n_scott_pearson
Super User Retired Employee
Hemnath,
In theory, you can use any SATA drive that you want in a RAID array. Some of the drive vendors have released drives specifically for use in NAS units that are purported to have better reliability; whether you spend the (extra) money for these is up to you.
...Scott
n_scott_pearson
Hemnath,
...Scott
