Intel® Desktop Boards
Peer-to-peer support only
11428 Discussions
dh87mc restart with no screen
mhlni
dear all
i have a dh87mc with 8gb kingston "kvr16n11/8" 1.5v x2
cpu : i7-4790 3.60ghz
ssd : Transcend ssd370 250gb
PSU : 400W
i work as an IT manager in a small company for 12 years now , i have tried everything possible , from the top to the bottom :
- reinstalling different types of cpu's ( Same thing )
-decreasing ram and changing ram manufactuers ( same thing )
-unplugging everything and replug it back ( same thing )
-remove bios batter , resetting bios , enetering the bios from the power button (same thing)
-installing an hdd 500 gg , kingston , hsdt , seagate ... etc (same thing)
-updating the bios (same thing)
so what are my options now i have an unsatisfied customer and a headache ... i am considering to replace the product ... what do you guys suggest ?
PS : even from bios when i save something and restart ... it restarts with a black screen ... under windows 7,8 and 8.1 same thing each time the thing restart i have to turn it off and turn it back on ... i even tried to convince the customer not to turn it off the answer was a bit ugly ... anyhow ... waiting for you guys to reply
thank you in advance ...
Kevin_M_Intel
Hello Bizo_biz,
Thank you for letting me know all the troubleshooting steps you have tried with this motherboard and let me say that you have done a very good job.
Please note that Intel® 8 series boards do not support the Haswell refresh processors. Third party boards may support these processors but with a BIOS update.
Here you Can find the compatible processors for this motherboard:
http://processormatch.intel.com/Processors/CompatibleProcessors?componentName=DH87MC http://processormatch.intel.com/Processors/CompatibleProcessors?componentName=DH87MC
Kevin M
mhlni
thank you kevin for your generous help
i5-4440 3.10 ghz did the job ... you know , i was in a hurry so replaced it with an asus 81 ... because the customer was in a hurry ..
thanks again...
we'll stay in touch ..
take care
Kevin_M_Intel
JBazz
Same issue with this board intel dh87mc using intel core i7 4790...running latest update bios.... any bios update or solution?
AlHill
Only one post is necessary. I have answered in the other thread that your board does not support your haswell refresh processor.
Doc
Larryvw1
Hi I had the similar problem everything works except restart
if there is no bios update then I can live with having to shut it off then start it
to bad Intel dose not support its older boards
AlHill
The latest bios is 0164, and is attached.
I have the same board, and have no issues.
Larryvw1
Larryvw1
Do you know how to get it boot from a NVE M.2samsung 970 evo
my MB is brand new it was the only new board that supported 1050 socket
my asus mb pins got bent and i did not want to through away a $500. cpu
thanks
AlHill
The DH87MC supports the 1150 socket, not 1050.
The Dh87MC board bios does not support/boot NVME.
What processor are you trying to use?
AlHill
Sorry, I did not see that you had an i7-4790 processor.  That is a haswell refresh processor.  It is not supported by the DH87MC.
Larryvw1
well every thing works except restart
will it support a nve m.2 in a pci slot converter it sees it in disk management and explorer
AlHill
Then, everything does not work.  That processor is not supported by your board.
Larryvw1
 you are correct I always get that wrong
n_scott_pearson
Super User Retired Employee
The 8 Series Desktop Boards does not support that this processor in their BIOS, so you will never be able to get into BIOS Setup with it. Still, I am told that the drivers will support the iGFX engine being used in Windows. I still think it is better to use an add-in graphics card (I am using GTX 1060 3GB in my Kinsley (DZ87KLT-75K) board).
There is no support in the BIOSs for the 8 Series Desktop Boards for booting from NVMe drives (unless the carrier card provides a OpROM-based BIOS driver specifically for this), but I have been told that you can boot from another (SATA) drive yet still have the NVMe drive be your System drive. UEFI Boot is required for this. It's a neat trick; one I haven't tried myself...
Hope this helps,
