after updating the Bios to V. 327 I can't boot from USB Devices anymore, they are not visible in the Boot menu (F10). Is this a known problem? After the downgrade to V. 326 everything works as expected.
Many thanks!
For the record: I'm not using UEFI, the Board is set to use CSM, Secureboot is disabled because I'm using a dualboot with Win 7 Pro and Archlinux.
Thanks for testing and sharing the results, I will pass this information to our engineering team. In the meantime, keep using BIOS version 0326.
Allan.
Thank you.
Another detail: when choosing F10 at start, I get the following boot devices listed:
P0: Sandisk SSD
IBA GBE Slot 00C8 v1403
Other attached drives are not listed here anymore. Maybe this is helpful.
Workaround: booting from various USB-Sticks works if the Option "Boot from USB-Devices first" is enabled. Tested with PartedMagic, Antergos and ArchLinux Live images.
