Intel® Desktop Boards
Peer-to-peer support only
display issue
rtopp
i bought intel dz68db motherboard and attached my processor corei5 2310
But there is some issue no display
I have changed dvi connector two times
But problem is same
It shows check dvi cale
What should i do
Allan_J_Intel1
Thanks for joining the Desktop Board community.
I recommend checking the link below for troubleshooting assistance on this no video issue:
http://www.intel.com/support/processors/sb/CS-030384.htm Desktop — Processors - My Computer Has No Display
Allan.
HRATH2
i got the solution
Allan_J_Intel1
Thanks for the feedback.
Allan.
HRATH2
Dear Rajendra,
If you have output through HDMI CABLE let me know i will give you the solution and it will work fine.
Do not replace or remove your motherboard.
Wait for a day i will send you my solution to your problem provided you make your output through HDMI CABLE.
Hemant Rathod
+919820862367
+919821862367
