Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
dp55kg i need help please
hi every one,first please sorry for my english
i just both aa dp55kg too building a 2u rack pc for live gigs with my band
i still have to get the processor, but i don t know betwen i5 or i7.
caus the case will be a 2u rack the space for the power supply is limited, the power supply that comes with the rack is this one
P1H-6400P
  • 400W
  • ATX 2.03,ATX12V(P4),EPS12V,WTX,AMD-GES
  • Server,Workstation,Storage System,IPC
225.00x100.00x40.50 (mm)
8.85x3.94x1.59 (inch)
VOLTAGE: 90 ~ 264 VAC FULL RANGE
REMARKS: THE OUTPUT POWER OF 5V & 3.3V NOT EXCEED 175W
*Active PFC (full range), MEET IEC-1000-3-2 CLASS D
*12V Max. Current : 28A
*TEMPERATURE RANGE: OPERATING 0℃ ~ 40℃
* HUMIDITY:OPERATING:20%-95%, NON-OPERATING:10%-95%
* REMARKS:85% IS NORMAL CONDITION AND 95% IS WITH SPECIAL COATING PROCESS
*EMI NOISE FILTER: FCC CLASS B, CISPR22 CLASS B
*SAFETY: UL 1950, CSA 22.2 NO/ 950, TUV IEC 950
*Remote on/off control
*Cooling: Dual 40 mm DC Fans
*3.3V /5V Remote sensing
*Serial ATA optional
there is anyone that can tell me if this power supply is appropiate for the dp55kg??
and aswell i would like to buy 4 x 4 gb ddr3 ram, i read in the forum that some people had trouble filling the 4 slots of ram, and there should be a specific ram that work good with this mob, please help me before i wast money for some ram and it will not work.
thank you very much in advance hope to get some help please.
Tags (1)
