Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
dp55wg shows Eb error after installing radeon hd 5750
OBran1
hi,
I have MB DP55WG with the latest BIOS, with i3-540, and until recently 9800gt Nvidia graphic card.
I upgraded the graphic card to radeon 5750 and it shows Eb error, not showing anything on the display, or getting any sign of life.
I have a replacement card - 8500gt, and it works fine.
I've checked the connectors, and they work fine.
how could i solve it?
DArce
Valued Contributor III
Please bear in mind that this product has reached its End of Interactive Support so Intel no longer provides interactive support for this product via telephone, chat or e-mail. Furthermore, no new drivers and BIOS will be developed for this product.
Is the Radeon 5750 card working in another system? If its working, then try updating the firmware of the video card you have installed.
If the issue persists, this might be a compatibility problem between that card and the motherboard, so you should check with ATI* for another card that has been tested on these boards.
