Intel® Desktop Boards
Peer-to-peer support only
dx58so wont start
NShar10
I have read many of the discussions regarding dx58so boot-up issues but mine appears to be a bit different.
Issue
I wanted to upgrade the BIOS via the USB method (http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm# usb Desktop Boards — Instructions for Recovery BIOS update), so I followed the steps given in that doc. I removed the jumper as given in url (above) so that the bios recovery is triggered, but that didnt work (no video, no beep, nothing). I waited for 15min or so and shutdown the machine. I replaced the jumper to normal and then started up again, but again no video, no beep.
I purchased a POST card and plugged that into the system to see any indication of an error and all I can see is 03 code. The intel manual do not help in understanding the post code but my guess is that the bios is somehow corrupted. I have tried many things suggested in various blogs/discussions and still clueless on the real problem (Ex. remove all mem and go to basic config to boot or use the jumper in config mode, etc). The system was working earlier, just that my hard-drive crashed before I embarked in upgrading the bios.
Is there a known issue in bios recovery? I purchased the board in 2010 so the bios should be during that time. Any pointers would be of great help.t_g
Silvia_L_Intel1
Hello Kaju,
First of all, I would like to inform you that this motherboard has been out of support since June, 2013. http://www.intel.com/support/motherboards/desktop/sb/CS-034322.htm http://www.intel.com/support/motherboards/desktop/sb/CS-034322.htm
However, here are our recommendations for this issue:
  1. What we recommend customers to do is to check how many versions are between the current BIOS and the latest one. Then, depending on that, install or flash 1 or 2 versions before getting to the latest one. https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20dx58so https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20dx58so
  2. Test the system out of the chassis, minimal configuration please. (Motherboard, processor, power supply, 1 memory stick and video card)
  3. Remove the CMOS battery and leave the system without it for about an hour. Then put it back on and restart the system. http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime
  4. Since this specific model has 26 different BIOS versions, which means there are many fixes between one and another, it will be very important to know which is the current BIOS of your motherboard in order to choose which BIOS we can flash first.
HSANR
Remove the CMOS battery and leave the system without it for about an hour. Then put it back on and restart the system, almost always works
